No, you wouldn't need to do an apprenticeship. It just helps by giving you experience which you don't necessarily need if going the academic route. I somehow missed that it was level 2. Level 2 is very basic, and mostly involves the same stuff as level 3, but on a simpler level. By far the biggest jump in terms of academic study and difficulty will be from ONC/D to degree level, or slightly less difficult by doing HNC/D.
Whatever route you take, it'll be a long time before you have a useful qualification - about 3 to 4 years for a HNC/D or 5 for a degree. Note that a HNC/D without experience in engineering is worth bugger all next to a degree with a similar lack of experience. Higher Nationals are very good to take whilst in employment in engineering rather than outside, and with them you can pretty much get to the same level of employment as someone with a degree (although that is largely down to the individual as well as the employer).
Higher Nationals are more practical and guided than a degree, but still include plenty of theory and also degree-level maths depending on the units you take (although a degree will generally be more mathematics-centric). The Higher National route can be easily seen as a cop out if you avoid taking on extra maths based units such as thermodynamics, further analytical maths, mechanical principles etc. and instead opt for more general units such as those which focus on planning, project managing and other specialised, non-mathematical subjects.
