I don't see anything wrong with it. it works fine.
5 Apr 2006
Stoke
So one of the lads on our irc chat for eve was asking for advice on upgrading his laptop to an ssd. then he was like o my fan is not working very well and the cpu temp is normally at around 100c or so, then he posted this pic up of the laptops cooling and i am amazed its still running.
He said he has the cpu set to not go over 60% load (how is that possible?) and that he has ordered a replacement heat-sink and fan unit for it.
Has any one ever seen a fan disintegrate like this?
I told him not to bother with the ssd and to save his £££ for future purchase's of a new pc or something as i cannot see an ssd helping at this stage..
This is the laptop spec.
http://h20565.www2.hp.com/portal/si...ac.admitted=1394980688639.876444892.492883150
100oc is crazy hot.
Whats class as safe/non damaging temps for laptops? I always though anything about 80oc and it would start to cause damage?
You can use the power management settings to limit how far the CPU will ramp up - also with laptops not unusual for software to come with it for extended power management options.
Intel range of laptop cpu's had a higher thermal fresh hold of 105c but I am not sure on AMD, looking at the website I can't see any info.
