I have a problem ? do screens need drivers ?
Suspended
30 Jan 2005
I recently brought this screen, and half the time its on it flashes black then back to the screen then back to black (its doing it now lol)
Do I need drivers maybe, or do I have a dodgy screen. Its this screen:
OcUK Value L1562S 15" LCD Monitor - Silver/Black (MO-008-OK)
OcUK's Value new 15" Multimedia LCD Monitor with high quality screen rescaling capability and Image Color Matching Profile.
- 1024x768 Optimum Resolution
- 400:1 Contrast Ratio
- Viewing Angle 160° horizontal, 160° vertical
- 20ms Response Time
- 250 cd/m2 Brightness
- One Analogue Input
- 3 Years Manufacturer On-Site Warranty - Call on 0207 9932753 or 0207 1019511 for warranty on-site replacement service and D.O.A.
All the plugs are in nice and tight.
edit: After reading some more posts here I checked my screen refresh rate at it was set to 70 so I have turned it down to 60. Maybe that will make a difference.
Windows drivers should be fine for most monitors. You could always try and install any that came with the monitor.
hopefully 60Hz will make a difference. if not try the screen on another PC if possible, see if you can identify if it is the monitor or the graphics card
