CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:12:24 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: JESPER-PC
OS version: Windows 7 Service Pack 1, 6.1, build: 7601 (x64)
Hardware: MS-7918, MSI, Z97 GAMING 3 (MS-7918)
CPU: GenuineIntel Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
Logical processors: 4
Processor groups: 1
RAM: 4047 MB total
CPU SPEED
Reported CPU speed: 3500,0 MHz
Measured CPU speed: 3850,0 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 15536,246708
Average measured interrupt to process latency (µs): 2,375455
Highest measured interrupt to DPC latency (µs): 175,248325
Average measured interrupt to DPC latency (µs): 0,466709
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 40,321714
Driver with highest ISR routine execution time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
Highest reported total ISR routine time (%): 0,034162
Driver with highest ISR total time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in ISRs (%) 0,088923
ISR count (execution time <250 µs): 1369835
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 234,747714
Driver with highest DPC routine execution time: netbt.sys - MBT Transport driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0,325507
Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0,606096
DPC count (execution time <250 µs): 6812133
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 0
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: avgidsagent.exe
Total number of hard pagefaults 9996
Hard pagefault count of hardest hit process: 5187
Highest hard pagefault resolution time (µs): 124929,147143
Total time spent in hard pagefaults (%): 0,187382
Number of processes hit: 39
PER CPU DATA
CPU 0 Interrupt cycle time (s): 25,719629
CPU 0 ISR highest execution time (µs): 40,321714
CPU 0 ISR total execution time (s): 2,647461
CPU 0 ISR count: 1369835
CPU 0 DPC highest execution time (µs): 234,747714
CPU 0 DPC total execution time (s): 17,207348
CPU 0 DPC count: 6568171
CPU 1 Interrupt cycle time (s): 4,009969
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR total execution time (s): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 127,822857
CPU 1 DPC total execution time (s): 0,212986
CPU 1 DPC count: 75171
CPU 2 Interrupt cycle time (s): 9,472041
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 147,202857
CPU 2 DPC total execution time (s): 0,170510
CPU 2 DPC count: 63667
CPU 3 Interrupt cycle time (s): 8,922871
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 83,839143
CPU 3 DPC total execution time (s): 0,454128
CPU 3 DPC count: 105124
