I recently sent back my Coolermaster 700m powersupply due to a fault which caused it to make a rather annoying high electrical sound while under load. OCUK sent me a brand new one and it's doing the exact same thing, I was curious if I could carry on using it till the ned of the month? WIll it be safe to use for that long? I'm pretty sure it's gotten louder, but seems to have settled down at a constant level at the moment.
Has anyone else with the same powersupply had this problem too? I wondered if it was a batch fault.
I'm looking to get a BeQuiet! power supply next, any good? Will be spending a good £120 on it.
Also, I decided to download Core Temp because I was curious to see the temps on my CPU -
These, to me, look high. Are they? If so, what could cause this
-Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366)
-Corsair Dominator 3GB (3 X 1GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel
-Gigabyte EX58-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
-EVGA GeForce GTX 260 "Core 216 55nm" SSC 896MB GDDR3 TV-Out/Dual DVI (PCI-Express)
-LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive
-Samsung SH-S223F/BEBE 22x DVD±RW SATA Dual Layer ReWriter
-Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366)
-Coolermaster HAF 932 Case - Black
-Coolermaster Real Power 700w Modular Power Supply
- WD 1tb HDD
- WD 1tb HDD
