I need help please read
21 May 2012
Hello this is my first time building a gaming pc and im thinking about water cooling my CPU,ram,motherboard and hopefully my graphics card. this is the case im getting Nzxt switch810.here is the motherboard im getting crosshair v formula/thunderbolt.here is the graphics card im getting sapphire radeon hd 6850 and finally im going with AMD 8 core processor with 16g b of corsair dominator Gt.
what i really need help is with how can i water cool my graphics card aswell as in what block i need,also what is the best size tubing and that is suitable for my blocks and fittings etc.
im also thinking of having a Koolance 5.25" Drive Bay Reservoir and Pump Unit : RP-985 as a bay plus reservoir drive and maybe a 250mm cylinder one as well so please help and it will be much appreciated thanks very much
and also is it a good idea to have to reservoirs and also would i need two pumps if so what ones also what blocks and tubing thanks
thanks i thought it might have been universal but its ok
i still have some un answered questions so here they are
1.what is the best size tubing to get which will support the cpu,motherboard block,radiaotr,reservoir,pump and graphics card block?
2.what are the best fittings for tht tubing?
3.what liquid should i use but it must be white because im having a white and black theme?
4.what setup is good for the nzxt switch 810 tall tower case?
5.what are the best radiators for watercooling?
6.im thinking of having a bay/pump reservoir and another cylinder 250mm reservoir would i need another pump for the build or not.or what else should i do?
i hope these can be answered thanks very much
thanks much appreciated i was wandering i fi could add u on sype if u have it to keep in contact and if i run into any trouble anlong the way u will b my first man thanks a lot
skype name:Pixelfix1
Post in the forums, it'll be a lot faster as either I or some of the many helpful users on here will be able to help you quickly :)
i got one word for you "Research" do that and its a piece of cake to build a pc and do a good water loop so watch vids and read guides and then ask the questions you aint sure about or maybe do a parts spec and we can look it over for you.
for starters you dont really need 16 gig of ram for a gaming pc 8 gig is plenty just get something like an i5 3570k,8gig ram and spend the extra on the graphics cards a 7850 would be good or push the boat out and get a gtx670
