I need some help with my loop!
30 Jul 2007
Derby
I have an EK X-Res/Laing DDC combo and an EK XTX radiator in the bottom of my TJ07 at the moment and an EK Supremacy CPU block, I'm wanting to go from my pump/res combo to radiator to GFX to CPU back to GFX then back to res/pump.
The GTX FC-670 full-cover block is coming today and I just can't figure out how I can go to the GFX block first then to CPU then back to GFX and then the pump/res in the bottom.
I know I could just route tubing from the CPU back to the res/pump but I kinda want it clean and the tubing to go back to GFX then through the mid-plate directly back to the res/pump.
So what I'm asking is there some kind of additional block I need?
don't know the block but sounds like you want parallel. if so, 2 fittings on the bottom of gfx, and top, 2 at top go to cpu block (observing which is inlet for cpu block as the hose going to the gfx card will then daisychain onto the cpu block, if that makes sense).
have a look in the build log section to get the idea, or just google parallel loops.
