i need your help please.. about Zotac 9300 for my HTPC
16 Apr 2009
Hey guys
im sort of a newbie to this..
I was thinking of purchasing this http://www.overclockers.co.uk/showproduct.php?prodid=MB-000-ZT
for my htpc.. the thing is, i might be looking to build some sort of mid-end htpc..
can I rely on the onboard hdmi graphics to output a beautiful 1080p? also i will want to add a soundcard asus D2 HDAV and a good TV tuner, the only problem is that this only have 1pci slot...
what should i do? also.. any good recommendation for best tv tuner card?
Thanks
Welcome djsmallz! You can have a look at my build using this board, it is available here.
You can indeed, it plays every Blu-Ray disk I have thrown at it without any issue. General desktop tasks and Vista Media Centre also run very well.
i will want to add a soundcard asus D2 HDAV and a good TV tuner, the only problem is that this only have 1pci slot... what should i do?
You will not be able to have both in the PCI-Express slot I am afraid. The onboard sound quality is not too bad; outputs 5.1 via HDMI, standard analogue outputs and S/PDIF.
If you want to have both, then you can always get a USB based sound card or TV tuner, or use an external amp.
If you want a normal dual freeview card for PCI-Express, then have a look here.
Oh thanks buddy.
erm.. Im going to trust you and go ahead with the onboard graphics.. i have an onkyo 905..it's an AV receiver, rvery powerful not sure if you're familiar with those.. i take it if i connect it to my htpc i won't really need a powerfull card?
as of tv tuner i have ntl and satellite.. is it any need for a quad tv tuner?
Oh thanks buddy.
erm.. Im going to trust you and go ahead with the onboard graphics.. i have an onkyo 905..it's an AV receiver, rvery powerful not sure if you're familiar with those.. i take it if i connect it to my htpc i won't really need a powerfull card??
I unfortunately do not have the space or funds for a decent home theatre setup. The 905 looks like a nice piece of kit. :D
A correction from my post above; the nVidia 9300 chipset on the Zotac board actually outputs 8 channel LPCM audio via HDMI, the onboard realtek sound is used to provide the analogue and S/PDIF outputs, which are limited to 5.1.
The HDMI connection should work very well with your AV receiver.
I cannot really help there, I am stuck with Freeview. If you have a set-top box, then you might need to look at a hybrid card. I have one in my build so that I can continue to use my 10-year old Dreamcast console! :D
