I really Need help
28 Dec 2007
Usually I am quite good at this sort of thing but I really need help!
I have a gigabyte P35C-DS3R board with a Q6600 blah blah
So I am upgrading the RAM to 4GB and am setting up a 160GB x2 RAID0 array.
I am installing Vista 64 as my new OS.
I have been following this guide roughly and at the end of this step http://www.legitreviews.com/article/454/3/
So yeh I looked on the Gigabyte website for drivers http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2746
I have tried all of these and nothing works!
I don't have a floppy drive, I am trying to install from USB.
These drivers do not work and I really need help.
So pretty much I need to find the RAID vista 64 setup drivers for a P35C-DS3R
Intel ICH9R/ICH10R Driver (Preinstall driver)
Note: Press F6 during Windows* setup to read from floppy. (For non-VISTA operating systems)
O.S. : Windows XP 64Bit,Windows Server 2003 Enterprise Edition 64bit,Windows Vista x64 (64-bit)
motherboard_driver_sataraid_intel_bootdisk_64.exe
Once you have created the striped array (CTRL C? from memory during post), Vista x64 should recognise it and have the raid drivers if not as opti says above you need the F6 drivers from the Gigabyte site or your m/board drivers disk. You may have to point windows to your usb stick if it cannot find them. Make sure you have the array set as the primary boot in the bios.
