- 18 Feb 2009
- Behind you
Just recieved a 3850 earlier today from the MM, removed the cooler to see what paste was being used and if it needed replacing and a load of washers fell off. I put them back on where i thought theyd fell from, but when i put the card back in and fired it up, i got a lovely burning smell, so i pulled the plug (power on to power off time was about 10 secs). I suspect i put the washers on the wrong side so that the cooler wasnt making contact with the chip, so i took it off once more (the paste has gone a bit yellowy, but the heatspreader seemed fine), removed the washers completely, rescrewed it, and shone a torch in between to see if it was making contact.
i put it back in the motherboard, powered it on, and the fan wouldnt spin, no heat was coming from around the chip area and (surprise surprise), no signal on the monitor.
any chance the oven trick would work?
sorry RomeoS...
sorry RomeoS...
RIP faithful old card
Drop it in a bucket of water and call the bomb squad immediately
