Yeah, if you work it out it should be around 716 I think. When you increase the FSB, you increase the CPU frequency and also the DRAM frequency, but the multiplier sets by how much. e.g. increase FSB by 2mhz with a DRAM multiplier of 2 and it will add 4mhz to the DRAM. CPU has a higher multiplier like 9, so 18mhz increase and so on.
When you get the RAM below 800, crank up the FSB again in steps and see where you get with it stable, (with DRAM less than 800 for now) then we can talk voltages!
Oh, and do make sure the RAM has enough juice to begin with, not sure what the RAM is rated at (2.1v maybe?), but the gigabyte boards usually give 1.8v by default, so maybe add +0.1v or 0.2v to the DRAM voltage so it doesn't interfere with OC'ing the CPU.
