I want a over kill PC
A custom loop yes, they do over time lose liquid (evaporation and precipitation though the tubing) , the all-in-one like a Corsair H100i are sealed for life and require no maintenance.
I am serious now I am looking as just had blue screen 116 and might as well buy a new PC as fed up of looking to see what the problem is. My case is too small to for a new graphic card in so if I buy a new case I might as well buy a new PC. I was only playing Far Cry 3 as well.
the £2981.95 seems ok price but not the £12k lol. Wouldn't buy that if I won the lotto that's too over kill for me.
Why do they allways put seagate HDD i don't like that make.
Just build a tidy 4790k Titan X PC and leave it air cooled. It'll be a damn sight cheaper than the ones linked to above and will be overkill for 99% of the time.
That sounds good. What to go with it. I want it so I can easily get to things later on if I ever need to change. Like now I cant even get to my RAM with out taking CPU cooler of its that big.
Intel i7-3770K
Gigabyte Z77X-UD3H
Corsair Vengeance Low Profile 8GB Kit
MSI NVIDIA GeForce GTX 670
Sandisk Extreme 120GB
Antec P183
LG GH24NS90
Noctua NH-D14 Cooler
Antec High Current Pro HCP-850
Windows 7 Home Premium 64-bit
That what I have now. All I keep getting is crashes on crashes and blue screen. I formatted it but no help. I also get bad stuttering in games. Like I say the case inside this is too small to fit another graphic card in and the CPU cooler is like a big tower block blocking my ram so I cant even get to that with out taking it off.
Its never been right from day one with HDMI to HDMI not working and 2 weeks later fan stopped on top of case. lol. Will not be buying from there again ccl I will defo buy it from here as more good reviews on service and build times. I had to wait 3 weeks be for I got it and they where making excuses up waiting for delivery even though it said in stock on website.
It a shame.
A new case and a closed loop water cooler (H110 etc) will fix your two smaller issues.
Then its a case of finding out why its crashing, if its overclocked try going back to stock.
It a shame.
Ive done all that going back to stock settings in bios etc. Not over heating according to GPU. Most games run at 82c.
Update the boards BIOS.
Use a single RAM stick at a time.
Is it crashing when even doing very little?
