i want to overclock my cpu but i have a few questions
11 Jun 2006
Middlesborough
firstly here is my spec
Windows 7 64bit Home Premium
Intel Core 2 Duo E8600
HIS iCooler V ATI Radeon HD 5850
Corsair Dominator 8GB (4x2GB) DDR2 XMS2 PC2-8500C5 TwinX
Asus P5Q Deluxe
Corsair HX 850W Psu
Samsung SpinPoint F3 1TB SATA
300gig Maxtor SATA
the main question is what kind of peformance gain would i get from overclocking? :) will it be noticable in games? or is it just going to be a extra 5fps here and there
what is the highest you would advise i have it at? i want it to stay at the speed all the time and not keep going into my bios to change it when i play a demanding game
lastly how do i do it? :p is it always best to push as far as i can go on stock voltages before upping them? or would it be better to up them a bit first?
i have a Titan Fenrir cooler installed and my cpu is the one with E0 Stepping if that matters :)
You can't go as high as you can go on stock voltages. Overclocking is increasing the voltage to in turn change the clock speed, voltages are usually automatically changed by the BIOS itself when you set a frequency.
I really recommend you read an overclocking guide first, I believe there is one somewhere on this very forum itself.
