I was bored today
Don
18 Oct 2002
Wargrave, UK
I had a laptop that some kids at the school had vandalised. Nothing special. Just an i3-5005U, 8GB, SSD etc. It seemed a shame to bin it.
May I present; Wall PC.
And yes, the 120mm fan is decorative only. It needed something to fill the space where the DVD drive would have connected.
It isn't a recess. It's 6mm MDF board as Zefan said. I was planning on spraying it black but forgot to do it and by the time I remembered I had half of the components mounted. Maybe I'll take it down and spray it up some other day I'm bored.
Not bad, not bad at all until someone touches the fan and fingers get cut to shreds, personally I would cover up the components.
Cut to shreds? Its not a turbine! lol. You can stick your finger in most PC fans and aside from a minor twinge which lasts a few seconds you'll be fine. :p
I wouldnt want to put my fingers in a Delta fan though! :eek:
