How did you cover the keys?
Wrong forum?
Looks like a decent job though![]()
Composition could be improved and the depth of field should be increased for the first two shots IMO.![]()
Buy an Elite?![]()
You try shooting handheld in this light with a smaller aperture, f2.2 and 800ISO was needed to get 1/40s![]()
*does 'straight over my head' hand gesture*
The finish looks appalling, as you said, dye would be a lot better.
(sorry)
Did you prep it with primer or seal it after spraying it? Just wondered, as if not it will more than likely start coming off with repeated handling.
