i2500k issues
Have you tried overclocking with a fixed voltage of around 1.35 to start with.
Set Vcore to Manual then type this value in.
I would also set VCCSA to 1.05v, PLL 1.9v and my DRAM volts to 1.65v to start with. Leave Speed step on but turn off all the Cstates and set LLC to med / high.
Then see how this goes.
Can you post more bios settings though please to look at such a digi power section etc. This will me to be a greater help and suggest more solutions.
Here is everything I have before I change anything again.
Ai Tuner - Manual
BCLK - 100
Asus Multicore enhancement - enabled
Turbo by all cores - 45
Internal PLL overvoltage - Auto
memory - 1600Mhz
EPU power saving - disabled
DRAM timing - 9-9-9-24 2T
CPU voltage - +0.0015v (1.36 in cpu-z)
DRAM 1.53
VCCSA Auto 0.925v
CPU PLL Auto 1.819
PCH Auto 1.062
CPU Spread spectrum Auto
LLC High
CPU voltage frequency Auto
VRM Disabled
CPU current capabilty 140
Thermal control 130
Everything else is Auto.
Do you really think I need to increase the VCCSA? it's at 0.925 also when you say increase the ram voltage to 1.65 wouldn't that be over volting it?
I have never had any blue screens just this occassional no POST issue.
No post is cold boot problems.
This is often memory voltage or IMC voltage.
1.05 VCCSA and 1.65v RAM is fine and well within accepted parameters.
I will change to fixed vcore and the settings you have advised. Thanks for your help.
I'll change them when I get home from work and run prime for a bit to see if it stable.
I will let you know how it goes.
Try VCCSA at 1.1v its still fine at this.
ok will do. Thanks for the help.
I wont be able to do this till the weekend but it looks like I am getting to the bottom of this as its been nearly a month since I changed to what you advised and it happened twice this week once on Saturday and once yesterday.
Thanks for your help again.
