i3 bundle ordered help needed
5 Feb 2009
- CPU: Intel Core i3 540 3.06GHz @ 4.40GHz
- Motherboard: Asus P7H55-M/USB3 Intel H55 (Socket 1156) DDR3 Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Akasa Nero S CPU Cooler (H70 Upgrade available)
Just ordered thanks to Stulid/cookehs help yesterday.
Is there a problem with that being 4.40ghz any risk of damage/explosions? Ive been told from friends it's very high
Thanks
That is a strong overclock. However if it has been brought from OCUK then it is stability tested.
Make sure you use decent brand PSU.
Shouldn't explode and there shouldn't be damage as long as its stable and not consuming a stupid amount of voltage or overheating
The system will work fine, like already mentioned use a quality PSU and you should be all set :)
What is the make and gpu are you using.
Not sure, already been using it for past year or 2 on my current 9800 GT, really not sure, how can i check without opening the case
Well i've found 600W Storm STORM-600W Black Edition, 23dB, 120mm Silent Fan, Black, ATX12V v2.0.
Literally all i can afford. Is that a good quality PSU? And will it do the job? Thanks
Indeed. You don't want to go buggering up that nice little setup coming your way due to a cheap PSU. You want solid dependable juice to that rig, especially with that overclock.
Wont cost too much to get something decent.
In fact, check this (must be pricing error)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-050-OC&groupid=701&catid=123&subcat=
I could literally just afford that then I'd have no money left to pay someone to build it for me, aha
