- 29 Aug 2010
- Cornwall
So my SFF PC seems to have died (turn it on and it doesn't post, GPU fans spin up, then spin down, then spin up, then spin down, etc.).
I'm coming from a Ryzen 3 1400 paired with an old 1070. It's only used for light occasional gaming and media duties.
So looking to replace it and thinking about either the i5 12600 or Ryzen 5 5600. Which is my best bet?
Also it's in a Silverstone ML08 case so there is not much CPU cooler clearance (147mm if memory serves). So I need something that doesn't run very hot. I don't think the stock Ryzen cooler will fit, not sure if the 12400 cooler will (does it even come with one?) and is it any good?
Would I be better off considering the Ryzen 5 5500 or i3 12100? Would they be upgrades from a Ryzen 3 1400 (@3.5GHz)?
Thanks.
Thanks.
