i5 2500k Overclocking Help
23 Nov 2011
North London
Hi i recently brought a system early December which consists of..
Intel Core i5-2500K 3.80GHz (Sandybridge)
Gelid Tranquillo CPU Cooler
Gigabyte Z68AP-D3 Intel Z68 Motherboard
HIS ATI Radeon HD 6950 IceQ X PLUS Edition 2048MB
Kingston HyperX 8GB DDR3 1600MHz Dual Channel Kit
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache
Antec TruePower New Modular 650W PSU
I have not yet overclocked the processor but I really want to do it but I'm not quite sure how as I'm kinda new to this stuff. if there is anyway someone could explain to me how to do it or no of any tutorials that show you how to in the simplest way. At idle I'm currently running around 27-30c , Full load around 45c
Enter the bios.
Ai Tweaker
AI Overclock Tuner- Manual
Turbo Ratio - leave this
By all cores - 46
Internal PLL Overvoltage - Enabled
Memory Frequency - 1600mhz
Dram Timing Control - Press Enter
Dram CAS Latency - 9
Dram RAS To CAS Delay - 9
Dram RAS PRE Time - 9
Dram RAS ACT Time - 28
command rate - 2
CPU Power Management - press enter
CPU Ratio - 33
Loadline Calibration - Extreme
CPU Voltage - Manual
CPU Manual Voltage - 1.365v 1.4v
DRAM Voltage - 1.560v
CPU Spread Spectrum - Disabled
I dont know if this helps, but this is the settings I use for my setup in the sig (Maybe you can play around with it abit) that gets it @ 4.6ghz stable for my machine.
I have a similar setup to you so maybe with a little messing it might work out? just I have an asus board. This is a sample profile that Ocuk setup for me - I have just changed it abit as there setup was not stable for my machine.
