Hi all, not sure its a problem as such i wonder if you could clear it up.
When my pc is idle according to cpuz my clock speed is jumping between 1600 mhz and my overclock of 4500mhz. What is the reason for this i can understand it downclocking it self when idle but why does it keep jump between my overclock and underclocking every 2 seconds.
The other issue when using prime its downclocking it self again to under the stock speed seems to hover around 3000mhz to 3200mhz. Surely it should be using the overclock of 4500mhz?
Another thing i dont know if its related or not since doing windows update it seems really slugish loading up my start up programs like steam and msi afterburner takes a good few minutes to get everything loaded up
So can anyone clear this up have i got something set up wrong some where.
Myboard is a asus p8p6 pro
