Hey guys I've done some overclocking and got the i5 2500k to 4ghz, I plan to leave it like this since I didn't mess with the voltages, I took a screenie to see if the voltages were at stock because I cant find the stock value voltage and would you recommend this for running all my time my computer is on?
edit: I disabled speedstep aswell
Would the windows plan affect the settings of the cpu? I'll check out my verison and then check cpu management. Thanks.
