My rough system spec.
i5 2500k @ 4.7Ghz 1.4v
GTX 570
Fractal 1000 case
Artic Cooling Freezer 13
So the 1.4v is the only way I can run my i5 at 4.7 stable. I don't mind keeping it there but the problem is cooling. In prime my cpu will top out at around 90c :O however in crysis 2 it will top out at about 70c.
I'm looking at keeping it a bit lower than that if I can.
So my first thoughts were to get a decent cpu cooler as this Freezer 13 is garbage :/
I'm thinking either:
Akasa Venom Voodoo £42.98 ocuk
or
Thermalright Silver Arrow £50.99 ocuk
Couple of problems though. Since I have a small case I might have trouble getting these in and even if I could: would they do any better than what I have currently due to the constraints of my Fractal 1000?
Am I better off getting a new case and cooler? Or will the cooler alone be sufficient in my case? Case wise I'm thinking Corsair 600T maybe if I have to go down this road.
Pic below to see the squeeze
Your thoughts?
GTX 570
Fractal 1000 case
or
Your thoughts?
