Hello. Ive just purchased the pc in my sig and only just put it together and must say its running flawlessly. Ive managed to OC the gpu to a decent speed and turned my attention on the cpu now.
Ive clocked it to 4.4ghz changing only a few settings so far which are
multi x44
vcore 1.25
cpu cache/ringbus 1.20
vrin-cpu input volt 1.9
My temps are a little on the hot side for my liking though 92.c 87.c 84.c 81.c after 2 hours of prime95 blend. This is the first time using Z87 chipset so inexperienced when it comes to OC these, my last pc was a 2600k Asus p8Z68 v-pro and had that at 5ghz 24/7
Could anyone help me out with getting a stable 4.2-4.4 the settings in this bios are baffling me and not much info on this board.
What would you call OK temps for this CPU?
Thanks
multi x44
vcore 1.25
Thanks
