Hi Guys,
Just started overclocking an i5 4690k, got it to 4.4GHz at a little over 1.2v which i thought was quite good but temps seemed far too high 95C+, seems high for small voltage?
Have clocked it down to 4.2 at ~1.18v but is still high 80s occasionally hitting 90, also the cores seem quite uneven - the highest is usually about 5c-8c different to the lowest. I have reseated and reapplied the thermal paste 3 times now with no change whatsoever (looked fine each time i took the cooler off).
I am using the Noctua NH-D9L, which is quite small but was hoping for slightly better results. Or was i expecting a bit much of a small cooler?
		 , ah well. I guess i was being a bit ambitious with that case, but thought i could get away with a small voltage increase and a decent cooler.
