For gaming the 6600k will be the faster chip, you get more cores with the 5660 but at the moment not a lot of games make use of more than 4 cores. This may change with DX12. Obviously the 5650 will cost a lot less than a whole new platform.
That seems like a good idea. A 5650 going for £60 recently but still probably best to put that towards a GPU.Hi, i am planning to get gtx 970 and wait till end of the year for the new pascal gpu's and the new intel chips and planing to build a new rig for next few years then.
Hmm, I can see X5650 going right now for £54 inc postage. I have a X5670 which I am using at 4.6Ghz but I'm not sure if it's worth double that of the X5650. Stock clocks are 2.93Ghz vs 2.6Ghz. Most X5650 do 4Ghz at a breeze and 4.2-4.4 if you spend a little time with them.
For DX11 the 6600K. For DX12, Mantle, and Vulkan the X5650.
Considering "future proofing"the X5650 is the way to go. Not to mention the massive cost difference.
Asus P6T, Bclk 220 (21x) 1.392v in bios.....
Wam7 what board and what bclk and volts?
Witch one would be better for gaming ?
The i5 has better per core rating but overall they are both the same.
Is it worth changing the socket if my mobo supports Xeon X5660
6600k will destroy the xeon in gaming and run much, much cooler.
You also get an up to date platform, all the new toys (connectivity wise) and full warranty.
Yeah, but it's not 50 quid![]()
