I5 9600k overclocking and stuff
2 Jun 2009
Hi there.
I'm in the middle of upgrading my rig. I've been forced to due to faulty/dead components. I finally did what I should have done in the start and that is buy a cpu, mobo, ram and cooler from overclockers.
For a start this is a budget gaming rig. No high end stuff. (Because that's what I do. Buy budget, unlock anything that can be and oc the arse out of it. It's my hobby)
I got a core i5 9600k as the cpu. Now before you amd fan boys get on at me, I got the intel chip for fast individual cores. I'm using it for games and emulators that need the fastest single cores you can get.
Anyway. This cpu I've ordered. I have a couple of questions.
Is there any way to turn off hyper threading on it? It's set at 6 cores, 12 threads. I want 6 cores, 6 threads. I want to maximize the speed of those cores as much as possible.
What's a decent every day oc for that cpu? For example, can it hit 5ghz using the multiplier and a small vcore boost and run like that day in day out?
9600 doesn't have HT, it's 6c/6t
Youd probably get 4.5 at best, maybe 4.6 or 4.7 if you have got a decent chip.
You're right. It is 6 cores, 6 threads. I must have misread the specs.
The 9600k already boosts to 4.9ghz single core at stock settings. 4.6ghz boost across 6 cores. That's why I said 5ghz across 6 cores. That would seem like a mild overclock for it.
I have the slightly older 8600k and it is fine at 5ghz and 4000mhz on the ram. Strong chips in real world performance. Just not so much on benchmarks.
I have a early 9600k and it does 5Ghz on all cores with very little tweaking other than the multiplier and vcore to 1.35v. Uncore is at 4.7ghz as well.
