i7 2600K Failing Intel Processor Diagnostic Tool
16 Jun 2010
Manchester
As title i ran this out of the blue and have tried rebooting etc etc and it still is failing, chip is stock.
See below :
--- IPDT64 - rev 1.1.0.0 ---
--- Start Time: 03/21/2011 21:11:42---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 64 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i7-2600K 3.40GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.40
Detected CPU Frequency is --> 3.41102
CPU Frequency Test Passed!!!
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 100
!!! --- Base Clock test Fail --- !!!
--- Test End Time: 03/21/2011 21:11:52---
I am hoping this doesnt mean my i7 2600K is fubar ??
My results same as yours:
--- Start Time: 03/21/2011 21:19:42---
Detected CPU Frequency is --> 3.40133
--- Test End Time: 03/21/2011 21:19:52---
The test does not support SB - it looks for FSB (front side bus) and SB does not have such a beast.
--- Base Clock test Fail --- is normal on the intel test with SB chips, it needs updating to support SB.. Ignore the FSB and Base Clock results. Also it can fail on the Integrated Memory Controller Speed Test (IMC) Ignore that one too.
Intel really need to get off their rears and update that program to work correctly with SB chips, it's resulting in a lot of working chips being sent back because of intels lazyness.
