Hi all,
i've managed to reach 5ghz stable on my i7 2600k but at quite a high voltage of 1.490. It seems stable and is cooled by a corsair H100 so heat is not an issue but i am aware that the maximum rated voltage for the i7 is 1.51 volts and during periods of heaving load (prime95 for example) CPU-Z shows the voltage reaching 1.52. Currently all the intel energy saving features are turned off (C1E, speedstep etc) so the cpu is pretty much running at 1.49 volts and jumping to 1.52. Do you think this is too high? Should i back off a little or would you guys deem this acceptable?
