- 19 Mar 2013
System Spec:
CPU: i7 3770k
Heatsink and Fan: Corsair H60 watercooler
MB: z77 Asus Sabertooth
Ram: corsair vengeance 32gb (4 sticks) 1866Mhz
PSU: XFX 850w
GPU: 2x XFX 6870
Ok so my overclocking experience is very little, up until a few months ago I was a complete AMD fanboy and had stuck with a Phenom II 965.
As it stands my CPU is running at 4.4Ghz, 1.296v. Now although this may look ok, it seems that my system doesnt like to go any lower in terms of volts and some sites suggest that going above 1.3v will start to kill the CPU. My temperatures seem to suggest everything is fine with this setup getting to medium to high 70 degrees when on full load.
Now the main issue is what am I doing wrong that I need such a huge amount of volts to get the cpu to work without issues. with the current volts im using really affect my cpu lifespan/degredation? can I go higher? should I be able to go higher.
The Corsair H60 review stated that it does perform better than high end air cooling so im trying to get my system to be around a comparable air setup (around 4.6-4.7).
If needed I can post screenshots, any help would be greatly appreciated.
Cheers
CPU: i7 3770k
PSU: XFX 850w
GPU: 2x XFX 6870
Cheers
