Do you mean i5, as that came in a 6600 guise. Else the i7 is 6700.I have a chance of getting an i7-6600 PC for free, I was wondering if it would be a decent upgrade from my old i7-3770k for gaming.
Do you guys have any idea or any good benchmark?
Thanks!
Is it a k version?
Use this site for benchmarks
https://cpu.userbenchmark.com/Compare/Intel-Core-i7-3770K-vs-Intel-Core-i5-6600/1317vs3514
Not a lot in it but you can OC the 3770k
Thanks!
Whole PC or just the CPU? Because CPU on it's own is incompatible with your motherboard and RAM.
That's good thinking.Sell both and buy something newer?
Great stuff then. Use itI currently have a custom build 3770k, while I have the opportunity to get my old office PC equipped with the 6700k non K. They both come with 16GB RAM, I would move the office motherboard in my case so I will take CPU, RAM, motherboard and cooler while using my case and PSU.
i would stick with the 3770k and overclock the nuts off it.
Would be intresting to know what motherboard the 6700 comes with and if its a single 16 gb of memory or 2x 8gb.I currently have a custom build 3770k, while I have the opportunity to get my old office PC equipped with the 6700k non K. They both come with 16GB RAM, I would move the office motherboard in my case so I will take CPU, RAM, motherboard and cooler while using my case and PSU.
If you're not overclocking and it has the same core/thread count, then it relies on clock speed and improvements to the cores. There are marginal improvements to each generation, so from a pure performance point of view, it's not going to make much difference. At stock settings the K CPUs don't offer you anything. If you had a heavily overclocked 3770k it would actually be a downgrade in performance.That's the plan as soon as I get a new GPU. Meanwhile, I'm trying to understand if replacing a K with a slightly newer non K CPU of the same class can bring any benefits.
