- 28 Feb 2012
- London
What would you say the safest max core voltage is for a i7 3820?
I wouldn't fancy going higher than 1.415v.
Why 1.4v+ is being recommended for this cpu? I thought sandybridge being 32nm could only be recommended vcore around 1.35-1.38v?
i only want to start off a little at a time lol....ill give it a go back soon lol
are ya done ye Mr roachy sah?![]()
I have a 3930K and I've settled at 4.6ghz 1.3V I could probably push further but heat will go up and I'd rather stay as low as possible voltage wise as it was rather expensive.
TBH you should just clock the chip at what it's comfortable at... usually they will go up to a certain point very easily with little voltage increase but then hit a wall where lots of extra volts doesn't do much. I generally just clock up to the wall because it's not worth all of the hassle to eek out a bit more with much higher volts (aside from internet bragging).
