mine had zero problems doing 4GHz with everything set to auro and the multi set to 40.
Heck, mine does 4.4 on everything set to auto.
As I said earlier in the thread, mine will do 5GHz at 1.41v, so 1.48v is HIGH!
I'll have a sneek peek through my BIOS when I get home and post up what I have to set to achieve 5GHz stable![]()
From my earlier post. I used an X79-UD3:
Overclocking is easy. I bought the 3820 a few weeks ago. All I did was set the correct memory timings and voltages, as the defualts were not correct for the speeds I was runnig at. I then chose the CPU voltage I was happy with. I then increased the clock till it maxed out at 4.5 ghz without failing prime 95 for 24 hours or so. I was happy with that as the voltage was high enough for me. Temps are low and system runs fine.
X79 has more life than the other chipsets as IB-E wont be out till next year.
Thanks for your specs and experience. Trying to get down to 1.4 myself now...
Yes but when they come out, Haswell will come very soon after creating the same situation that existed before 2011 emerged, that being the enthusiast platform (at the time the 1366) being less powerful than the 'home user' platform (at that time the 1156).
1156 was never more powerful than 1366. 1155 arguably was, but that depended on the usage.
Agree. But I wanted longevity with my platform over a longer term of say 4-6 years. If you can afford to change your whole system every 2-3 years then its always better the other way. If you see my other posts I paid £80-90 more for a quicker current platform than a 2500k platform, but I can probably slot in a hexa core in a few years and a new GPU and still have a quick system as opposed to change everything inc my mobo etc too.
Well no, they built the easiest to overclock, and best bang for buck system they could for £2,000.
Had you wanted to go heavily overclocked 990X, you'd have needed much better cooling, more expensive motherboard, higher clocking RAM, and a lot of patience messing around with a lot more than a few voltages and the multiplier. Then the CPU would have cost almost half the budget alone.
