i7 4790 with 4070 Super
8 Aug 2015
I'm looking to do a big upgrade soon, ideally to 9800X3D if I can be patient enough. I recently saw a great deal on a 4070 Super and jumped on it, so in the meantime I'm on an i7 4790 (non k) with a 4070 Super. Coming from a 2060 Super I'm surprised at how little extra performance I'm getting with the 4070 Super.
I would say around +5% - +10% in fps but 1% lows haven't changed much. Mainly play GTA V, PUBG, Diablo IV @ 1440p.
There is obviously a major imbalance between the CPU and GPU but I am surprised at just how much. Does this sound about right or should I be getting more?
My existing board is a H81 (PCIe Gen 2)
you need to check your cpu utilisation
if it's already pegged at 100% then your new 4070super is severely bottlenecked
For the same price as just the 9800X3D is likely to cost you could do a full AM5 upgrade right now, I doubt there would be a noticeable difference at 1440p on a mid range card like the 4070S compared to the much more costly 7800X3D/9800X3D.
My basket at OcUK:
Total: £454.97 (includes delivery: £0.00)​
My basket at OcUK:
I've been sat with that exact same spec in my basket for the past week (however with the 7600x and the crucial PRO OC 6000MHz CL30 kit)
Does the G.Skill kit have any benefit over the crucial set?
I think I'll probably just pull the trigger this weekend... Waiting is torture
The Gskill kit has better timings CL30 vs CL36 from the crucial so I'd say that's worth the extra tenner.
Is there any way to measure this? Like an option within the rivatuner/afterburner software.
Yeah, by decreasing resolution and graphics settings, but not getting much more fps you can work out when you are CPU limited. [with game engine issue exceptions for high frame rates]
Task manager can be tricky. The overall % utilization isn't too helpful. You are really trying to judge when a single core hits 100%. Games get diminishing returns after the first core. Some are better than others at sharing their load.
Beyond that in your case you have additional factors that are starving the cpu. 1600hz DDR3 is a killer. You might be just running it at bios defaults and its true specs might be more like 2333/2666.
Correct me if I'm wrong, but not particularly demanding games those? Ideally, you'd want to ramp up the graphics settings to max and play graphically demanding games that don't hammer the CPU. i7-4790 non-K is a decent CPU for older games, but for newer games the low clock speed and single thread will be a bottleneck.
I had a 4790k with a 1070. I upgraded to a 3070 and definitely noticed some improvement.
Then I changed platform to a 7700x and it was like I’d upgraded my GPU again.
A 4790 cripples a 4070s.
Last GPU I used with a 4790K was a 2080Ti and even that was a CPU bottleneck. I've updated CPU twice since then.
Good chip for it's time, but things has moved on. Not sure how you've managed with a 4790K in modern titles tbh. lol
I ordered the following over the weekend: 7600x, 32GB DDR5 6000MHz CL30, B650 Tomahawk.
in summary, the i7 4790 was completely hamstringing the 4070 Super (big surprise) but by how much was just astonishing.
