- 11 Jun 2013
Gone from 4770k to 8700k - couldnt be happier with the performance gain. So now it comes tp overclocking.. Heres how easy i achieved 5ghz, and my question about safe voltages.
mobo asrock z370 extreme4
i changed to All cores, 5ghz
vcore i changed to offset and voltage +50ma
under stress testing the vcore voltage goes as high as 1.37v - temps are in the 60c range spiking around 70 ( h115i cooler ) which i dont think is too bad considering this hot weather were having and i imagine under normal weather conditions that could drop 5-10c.
So my question... is 1.37v spikes on vcore acceptable?
