- 1 Dec 2017
Have you not tried a slightly lower speed? A couple of hundred Mhz isn't going to make a difference in performance.
If you're adamant on 4500Mhz you can try increasing VCCSA and VCCIO voltages. Try setting both of them to 1.2v. Realistically they're going to need to be minimum 1.15v to run ram at that speed.
I assume they're on auto, so what is the motherboard setting the voltage at?
The Apex (and high end itx boards) is pretty much as good as it get's in terms of memory overclocks due to having only 2 dimm slots, so you've got a good foundation. But it comes across as though you're not willing to try and tweak anything.
While we'd all love for everything to be plug and play, it often rarely is with PC's lol.
I tried 4400 with same timings and 1.45v. That didnt boot. Tried the 4266 too and that didnt boot. Tried with higher voltage and that didnt work either. Then i gave up as going further down was simply not worth the money. I could buy a cheaper dimm which would possibly achieve that.
I see people keep comparing this to supercars. At least supercars turn on as soon as you turn the key or click a button. This RAM is not plug and play whereas supercars are good to go when you buy them.
