Hello,
I've had a go at overclocking my I7 920 - I started using the Asus Turbo app that came with my P6T M/b however it seemed to be pretty useless.
Used BIOS in the end, I read some guides from here and toms hardware and half the options on there i couldn't find on my BIOS -
So to cut a long story short, sorry I have a tendancy to ramble on. I've changed the clock speed to 162mhz x 21 - I have left all the rest of the settings for memory and voltage on auto and it i have a clocked speed of about 3.4.
The voltage seems to sit around 1.240 - is this ok?
also the temps seem to max out at around 75-80oc when under stresss tests using prime95 - This is cooled by air, althogh my cpu cooler fan has a max rpm of 880 so i can change this to a new one which should help a bit.
Cheers!
Cheers!
