Hi Guys
I just got my new goodes from OCUK yesterday.
Intel i7 950
Gigabyte GA-X58A-UD3R
6gb OCZ i7 Edition memory
plus 2 GTX265
Running a tagan 1100w psu
2 x 150gb wd raptors
1 x 1tb
LG DVD drives
Im having problems getting windows 7 x64 installed, it bombs out at 70% of the install - even Vista x64
Things ive done.
Updated bios, Changed HDD, changed DVD Drive, Changed Windows 7 install DVD, Changed sata/raid setups also installed drivers for sata controlers from motherboard DVD at install, oh and used 1 or both GFX card in different orders.
Now the funny thing is i can install Win7 x86 but as soon as i run system rating, wait till it gets to checking the cpu and it crashes. Ive checked the system temps and the highest ive had it is 61c at crash.
It hovers around 30c when doing nothing.
Ive also noticed at the post screen the board things its a 3.2ghz but as soon as you go into the bios or windows it says 3.06
Any advice guys
Intel i7 950
plus 2 GTX265
1 x 1tb
LG DVD drives
Things ive done.
Any advice guys
