I7 C-State @4.2HT Help ?!
26 Jan 2004
Scotland
Im trying to get my clock to report 4.2ghz HT with Cstate enabled so that it down clocks when idle.
though im having issues
i normaly run 24/7 200x21
but when i enable c state and turbo i end up getting a 22x mulit that makes my cpu under load reach 4.3ghz
is there anything to change to disable the 22x multiplyer i didnt even know i7 920s had 22x multis lol
and if i enable c state and disable turbo my cpu under load runs at 4.0ghz and doesnt change to the 21x multi. for 4.2.
suggestions ?
well will everything enabled under load it jumps to 4.380mhz
with 200x22+powertech.
i dont really want to drop bclk as it will lower my memory clock as its already at 1600mhz with 7.7.7.21 T1.
there must be a setting so that it doesnt use the 22x multi.
if i disable the turbo tech all i get is 200x20 but no 21x multi. its like it vanishes. and also speeds dont go up and down stays at 4.0ghz only.
i thought speed step did that not turbotech.
The above suggestion makes the most sense. i7 920s will go to 21x under load using 2-4 cores and 22x under load with a single core. You won't notice any slight reduction in RAM speed.
depending on mobo, you can just turn off turbo function, but still use the 21 multi, i know i can if i wanted too.
Not on my motherboard you cant when i enable turbo i cant get the 21x multi only 22x with turbo disabled and c state enabled i get 4.0 only and speeds dont fluctuate lol
