11 Aug 2009 at 09:31 #1 widdyst widdyst Permabanned Joined 5 Jan 2008 Posts 1,300 I'm running a 965 i7, now i have used 3 programs to sense temps and have found a big variation at idle, Core temp says - 38 Asus ai suite says - 29 Everest says - 29 Any ideas why core temp would read so much higher ?
11 Aug 2009 at 10:10 #2 metamorphpwner metamorphpwner Associate Joined 6 Sep 2008 Posts 2,111 Location Near Hull for me real temp and everest read a 10degree difference, everest bieng the lowest.. not sure which to believe now.
11 Aug 2009 at 10:19 #3 invisible69 invisible69 Associate Joined 24 Apr 2009 Posts 151 Location Malta use core temp. the others read the sensor which is outside the chip so to speak. Core temp reads the on die sensors.
11 Aug 2009 at 15:55 #4 widdyst widdyst Permabanned OP Joined 5 Jan 2008 Posts 1,300 Ah ha I see so core temp is definitely the most accurate then
11 Aug 2009 at 16:01 #5 oggiet oggiet Associate Joined 10 Jan 2009 Posts 1,511 I trust realtemp the most
