- 8 Jan 2009
Hi, I'm new to these parts so please go easy on me
Firstly, hello to all.
I'm looking to buy a new rig for gaming and have ended up a little confused between the 920 and 940 i7 cpu's.
What is the actual difference between them, apart from about £200 and 0.26Mhz clock speed?
Is the 940 just a factory overclocked 920 or is there more to it than that?
I don't upgrade very often, so the i7 will be with me for a few years and as such I want to make the right choice as I normally spend a bit more on the processer and mobo and then in the future I will upgrade the gfx card etc to get max time out of my system.
I suppose what I'm really asking is, if I buy a 920 and o/c it a little bit, will it perform the same as a 940, draw the same power and run at the same temps.
Is the 940 really worth that £200ish more?
I saw another post the mentioned the the 940 had a internal higher bandwidth?
I think thats just confused me more.
Anyway, thanks for any replies,
Jonney.
Jonney.
you sound like you have been out of the hardware scene for years and years and years!
