Pushing it on a 750w I'd think. As a min I'd guess you'd see 500w pulled from the wall on that set up - doesn't leave a lot of breathing room.
FYI, on my build I see regular peaks of 550w and an OC'd 7900x is similar in power consumption to an OC'd 1950x
Seasonic yep , superflower (the gold and plat) yep , XFX , nooooo , junk , poorly made had a few of the 1050w recent ones all failed , a friend had a 1050w that failed and a 1250 that buzzed and eventually failed, they look good and thats about it.
I hazard a guess that its the reason Overclockers don't stock the 'higher end' XFX psu anymore.
Just the designed platform, the component choice depends largely on the budget that XFX allows.Nope. Seasonic make most of the XFX PSU's
I got one 850W XFX black edition died on me as well, waited for 3 months for a replacement, got too tired and asked for a Corsair SF600 instead.Seasonic yep , superflower (the gold and plat) yep , XFX , nooooo , junk , poorly made had a few of the 1050w recent ones all failed , a friend had a 1050w that failed and a 1250 that buzzed and eventually failed, they look good and thats about it.
