ICE Advice plse...
18 Oct 2002
England
Really no idea what I'm doing ICE wise - I just want to change my double din unit to something a bit better (and single din to get some storage space) and I want something where you can change the colour of the display to red to match the interior.
Went to my local place & told them I dont want to spend any more than about £300 plus fitting for a HU and some component speakers.
They're coming up with a Pioneer DEH-P55BT - £229 and some half decent 6 1/2 inch speakers are about £70. They want £30 + VAT and hour fitting - 2 hours approx. Does anyone know if I can plug a USB type MP3 player into this model? I dont have a CD burner - just want to put tunes on a USB MP3 player and plug that into the HU.
Do these prices sound ok and is the HU any good? I dont want an amp or a sub or any of that stuff - it weighs too much.
Ta. :)
That is a lovely headunit - multi colour options bluetooth for phone. You can't use a USB mp3 player BUT you can pick up the ipod control adaptor for a snip.
Sounds like a good deal to me!
How about one of the newer alpines, im sure they have silly amounts of colours that you can choose.
Hmm :(
Dont want to spend money buying an i-pod + adapter when I can get an MP3 player for peanuts.
I had a play with the alpines - looked gorgeous, but the menu systems were confusing - very finicky and awkward to use especially in a car that has a rock hard suspension - my fingers would be all over the place pressing the wrong buttons. Also on the ones I looked at - the display colour you could change np but the buttons stayed blue which just was stupid.
Firestar_3x said:
a CD Burner is £12 and dvd burner £34 ;)
Ahh. Well that's different then - last time I looked a DVD burner was £400. Kinda lost interest in computer things over the last few years....
Right, so if I buy a DVD burner - can I put my albums on it and play it in the car and will I need any special software to do that?
Nero + Mp3's burn ont a CD, simple as, unit will pick up the files and directorys and you can navigate between them.
Should get a 140ish songs per CD (Depending on quality).
Don't think your unit will play mp3's that are burnt onto a dvd.
NEC ND4570 16x16 DVD±RW Dual Layer ReWriter (Beige) - OEM (CD-029-NE)
The ND4570 is the latest drive from NEC offering DVD - RAM recording, giving this unit the best specification on the market.
- DVD+R: 16x, DVD-R: 16x
- DVD+R DL: 8x, DVD-R DL: 8x
- DVD+RW: 8x, DVD-RW: 6x
- DVD-ROM Read: 16x
- DVD-RAM: 5x
- CD-R Write: 48x
- CD-RW Write 32x
- CD Read: 48x
- Access time: 130ms
- Buffer Size: 2MB
Price: £23.95 (£28.14 Including VAT at 17.5%)
http://www.overclockers.co.uk/acatalog/DVD_RW_Drives.html
Have you seen the ones with the long bar rather than the buttons, you just move your finger along the bar
Yeah, that's the one I looked at - lol it'd be a total nightmare. :p
Definately want something that will take an MP3 player - reason why is that the car is a bit stiff and I always get CD's skipping as I go over even slight bumps - drives me mad & with an MP3 player that wont be a problem.
Don't get this problem tbh and my car isn't that forgiving over the bumps, a good mp3 unit should cache some of the song to memory so should have 1min + shock protection.
Skipping shouldn't be a issue with a decent head unit. Even my 3 year old Kenwood MP3 headunit doesn't skip, and my car might as well have no suspension, these TEIN coilovers are that rock solid.
Saying that though I don't know if it would skip on normal CD's, I only ever listen to MP3 compilation CD's, but I've never had one skip.
The skipping is really bad, I thought most modern HU's had a buffer but this Clarion thing can't remember anything. Sometimes the whole track resets to the start. :mad:
Definately want an MP3 compatible one. I'll order an MP3 player using my works account and tell them it's a USB pen drive for me to move files around with, net result - MP3 player free of charge ;)
Just waiting for some cash from selling my old wheels & i'll book the car in.
What about the DEH-30MP? I've got the catalogue in front of me but it doesn;t show prices.
£89.....
Powered by Pioneer’s MOSFET 50 and incorporating EEQ+ precision tuning with High and Low Pass Filters, the DEH-30MP boasts a Direct Rear Aux-In so you can hook up any MP3 player and enjoy the DEH-30MP’s full MP3/WMA/WAV capabilities.
Want to impress with mind-boggling power bass? Its Direct Sub Drive allows you to drive a subwoofer directly from your headunit, without an expensive amplifier. With 2 RCA Pre-Outs you can add an amplifier and speakers, and raise your in-car music experience to unheard levels.
Engineered to impress, the DEH-30MP comes wrapped in distinct designer looks and fitted with a blue back display. Simply stunning.
Main features
AUX-Input
LCD-Blue Display illumination
Cellular telephone auto muting
No. of Radio Presets 18
Max. output power (watts) MOSFET 4 x 50 Watt
RCA Preout 2 (F + R or S/W)
Features - General
CD Text
Remote control Optional
Hard-wired remote input
ISO Connector ready
Rotary volume
Front Panel Removable
Flexible angle installation 0-60°
Features - Tuner
Adaptive RDS (PI, PS, AF, TP/TA)
ARC FM D4Q
BSM (Best Stations Memory)
Features - CD player
Oversampling digital filter 8x
D/A Converter 1 Bit
Fast forward/reverse
Track Search/Scan/Repeat
Random Play
Last position memory
CD-R Playback
MP3 File playback
Windows Media™ Audio playback
CD-RW Playback
WAV File Playback
Features - Audio / Amplifier
HPF (High Pass Filter)
LPF (Low Pass Filter)
EEQ Plus
Selectable Loudness
Selectable FIE (Front Image Enhancer)
SFEQ (Sound Focus Equaliser)
Source Level Adjuster
Fader
Specifications - FM
Frequency range 87.5- 108 MHz
Usable sensitivity (75 ohms) 8 (0.7 µV) dBf/µV
S/N ratio 75 dB
Frequency response 30 - 15.000 Hz
Stereo separation 45 dB
Specifications - MW
Frequency range 531 - 1.602 kHz
Usable sensitivity 18 µV
Specifications - LW
Frequency range 153 - 281 kHz
Usable sensitivity 30 µV
Specifications - CD
Frequency Characteristics 5 - 20.000 Hz
S/N ratio 94 dB/1 kHz
Dynamic range 92 dB/1 kHz
Specifications - General
Chassis size (W x H x D) 178 x 50 x 157 mm
Tis pants.
Your best getting a highend unit the using the CD changer control plug with an aux in adapter lead, this way your not limiting your HU choice.
Leads are cheap as :)
Seems I can't have my cake and eat it with the Pioneers. This is what I'm after ideally -
Total colour control (or just plain red as standard)
Will take an MP3 player
Single DIN
50W x 4
£200 - £230 budget for te HU.
Kenwood KDC-W808
DMask+ removable faceplate
2-steps angle adjustment
Disabled System Indicator (DSI)
Protection case for faceplate
4 digit code security
Full dot (96x23),
2 steps automatic dimmer
Display blackout
Spectrum analyzer
Selectable key illumination (red or green)
Digital clock (24H)
Remote control sensor
All-off select (20/40/60 minutes)
Built-in fuse/coil
Disabled system indicator
2-way telephone mute
Hard-wired remote-in
External option control
OEM display out
Ready for iPod (KCA-iP500)
AUDIO FEATURES
4 x 50 W max. output power
MOSFET amplifier stage
3 RCA pre-outs, 5 Volt
1 RCA AUX input
Subwoofer ref. level adjustment
Build-in amplifier Cut. off
Installer memory
Tone control: Bass/Mid/Treble
Source tone memory
Loudness control
System Q sound system
System E’s+
2003/2004 BMS amplifier control
TUNER FEATURES
RDS tuner with Radio Text
24 Presets: 18 FM, 6 LW/MW
Auto Memory Entry (AME)
Up/Down seek tuning
Auto1/Auto2/Manual tuning mode
Stereo/Mono selector
K3I clean reception tuner
DAB reception with optional KTC-9090DAB tuner
CD FEATURES
CD-R/RW playback
MP3/WMA/AAC playback
CD-Text
L/R 0-bit mute
24 bit DAC (Burr Brown)
mCD application software
Voice SSA
Random/Repeat/Scan function
8 Times oversampling
Signal-noise ratio: 110 dB
Dynamic range: 93 dB
Channel separation: 96 dB
Our Price: £219.99
http://www.caraudiodirect.co.uk/product_info.php?products_id=4493
Red Colour is only for the buttons screen text will still be blue, but it does everything else and i do rate the kenwood SQ quite high, i've got an expensive Kenwood unit in the MX and it sounds great is easy to use etc, i don't quite win a cookie but will keep looking.
Bass Junkies have the JVC KD-G821 which will take a USB flash drive. It looks like you would run the mp3 player from a standard USB cable. It shouldn't sound too bad with decent speakers...
Edit: I'd try a decent headunit in your car. A decent one shouldn't skip day to day unless you are nailing it over speedbumps!
