Sorry if you've already read this on the MB forum, but only just realised this is a better place to ask for help...
Hello, I'm hoping some one can help me as I've spent hours trying to get the following set up to work.
I have an Asus p5k Premium motherboard which has been working fine with 3 sata drives and sata set to IDE in the the bios.
I have now bought 2 Icy Box IB-390 docking stations and seagate 1tb drives to allow me to add extra storage and allow me remove my photos from the PC when required, however I've found I can't get the IB-390s to work.
The drives in the Icy Box docking stations don't show up in Vista 64 bit nor bios.
Motherboard bios is the latest version I can find, ie. 11.01.
I've tried changing sata setting to AHCI and rebuilding, the icy box drive is still not seen in bios nor Vista 64 bit.
I've also tried plugging the docking stations in to different sata ports on the motherboard, currently using sata1 and 2 for the master hard drive and primary data drinve and 3 and 4 for the icy box docking stations.
If I plug the Icy Box caddies in using USB or E-Sata then they are picked up by vista and I'm able to use them.
However, the aim of buying these was to use the docking station so I would really like to get them working if any one knows how please.
I'm assuming the hardware isn't faulty as I have the same problem on both units and am using drives which I've used ok connected directly to sata ports.
Thank you.
Thank you.
