I received one of these bad boys for christmas with a Samsung F1 1Tb drive. Unfortunately the first one i recieved had a faulty spring for the eject lever so had to return it, this replacement seemed ok at first...
Basically i've fitted it into the caddy, formatted it to fat32 (so i can use it with my PS3 too) and all was well via USB. I then fitted the enclosure and unfortunately it doesn't work in there at all.
The power light comes on, but the harddrive activity light doesn't flash at all, i've checked the connections, switched which sata connector on the motherboard it's attached too and nothing. The motherboard doesn't see it at all and the only hint i can see is when i boot windows in device manager one of the SCSI host controllers has an error:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Can't figure out how to get it working, if i slide it out of the caddy and connect it via USB it's perfectly fine.
Motherboard is a A8N-SLi. Any help would be fantastic.
