rpstewart said:You can either go with a PCI card with it's own controller but an easier option if you have a free mobo port is to use a PCI bracket port which connects the internal port to the outside world.
Sorry for gate-crashing, but I'm in a similar situation. Bought an esata Seagate Freeagent, and can't get windows vista to reconise it. Any help would be welcomezom247 said:Thanks for that. I just happen to have all the kit required so I've tried this. The drive works fine if I switch the enclosure on before starting windows xp but if I switch it on after windows has loaded the drive is not recognised. Do I have to change anything in the BIOS for it to be recognised?
