IDE Drives
31 Mar 2009
Stoke-on-trent
I've currently got two IDE hard drives and two IDE optical drives.
My motherboard only allows to IDE cable to connect to it.
Is there any way to connect another IDE hard drive?
Cheers in advance:)
You'd be best off with a PCI IDE card then. I don't know whether these allow you to boot from them but they'd be fine for a storage drive.
Allows two cables?
Can't you run two devices off each cable? Hard drives as master and slave on IDE channel 1; optical drives as Master and slave on IDE channel 2? If you jumper them as CABLE SELECT, it should be plug 'n' play.
Did I misunderstand? :confused:
EDIT : NM. It has sunk in. OP has 3 drives. :o
IIRC, you can get SATA / IDE adapters. Or you can get IDE / USB adapters, complete with power brick. I have one of the latter and it cost pennies.
