Drive gets hot so I presume it is spinning, it was working OK when inserted. The adaptor light is on and is connected through the hard wires in the PC with a SATA cable to the motherboard.
It did install a driver at one point but turned out it was for the master HD. I think it would have to detect the new drive before it installed a driver. I have run it on an IDE machine at work so the thinking now is that the adaptor is duff so I will try another just to be sure.
