IDE HDD
No idea what the third connector is without a better description.
The mainboard uses the via 8237 chip, which has the standard 2 controllers 4 channels setup. No more than 2 drives should be connected to each IDE port on the board, so get a new cable and put the HDDs on the Primary channel (Blue), closest to the front of the case, and the to CD-ROM drive on the other.
