Hi
I have a couple of SSD drives fitted an recently installed Win 64 bit. I left the storage as IDE is this correct? Does it make any differenece as I seem to remember that ACHI was better...
Not fitted as Raid...
jorel
you dont need to reinstall anything,just run this reg file now,and reboot into bios set to ahci for all your drives and save/exit/boot into windows and thats it,youll see windows install the ahci drivers,then install irst intel rapid storage drivers to improve speeds further
