IDE or AICH?
20 Jun 2009
UK
Just got my GF a laptop, but it keeps BSODing. I've not had time to send it back yet but noticed the 320Gb Drive is set to AICH in bios if u change it to IDE it will just loop at windows start up.. I'm I correct in thinking the drive not been a SSD should be set to IDE and windows be installed from fresh set to that? Thanks.
No, AHCI is the optimal setting for a SATA drive. The reason it loops when set to IDE is because you cannot change them when you already have Windows installed. You need to set it to whatever you want, then reinstall Windows with that setting.
Or do a registry edit under Windows 7.
Cheers.. looks like I will be sending it back.. I did ask OCUK but as its 3 wks old they said contact MSI, nothing is simple with MSI from past..
Thanks Guys
Thanks Guys
First year of warranty should be with the retailer. If you bought it through OCUK i'd request an RMA through them as well.
Thanks Guys
OcUK should take care of you:
Just to clarify another point as well, if your read our support page carefully which is linked to in the OP of this thread you will see we clearly state:-
1. After the product is 28 days old you can either RMA with ourselves or the manufacturer.
To clarify this means you can either RMA back to ourselves or the manufacturer, the choice is yours.
So for instance it makes sense to RMA back to us, if the manufacturer does not have for say instance a UK RMA support facility, for example Sapphire. So with Sapphire you'd RMA the product with OcUK in the 2yr period, we will honour the warranty for the full 2yr period, or in the case of Asus 3yr etc. As we understand some manufacturers are not so easy to deal with and here at OcUK we want to ensure you get truly the best service and support.
However in some circumstances the manufacturer can offer a better service and quicker turn around time, for example KFA2, Gigabyte, Hard drive manufacturers and EVGA are famous for top level customer service and RMA support with quick turn around times. With these manufacturers we'd recommend you deal with them, simply as they can support and turn the product around quicker giving better service. Though again of course if the customer wishes we will deal with the product ourselves for them. What I would insist though is with printers, laptops and monitors after 28 days it is very advisable to deal with the manufacturer because many of them are actually on-site warranties which are the best and obviously like all other Etailors OcUK does not offer on-site warranties.
So just to clarify, after 28 days the choice is yours, you can deal with the manufacturer or OcUK, we will be happy to assist and do the best we can to offer the best service and attempt to get ourselves regarded as the best online etailor when it comes to RMA service. :)
Please remember though warranties, don't cover an end-user physically damaging a product due to in proper installation etc. or wear and tear, or in some cases modification. For example EVGA are fine with heatsinks being removed from VGA cards, as long as no damage is caused and they are re-fitted correctly if the card needs to be RMA'd, wheras other manufacturers removing the cooler voids warranty.
**14 DAYS SATISFACTION GUARANTEE!**
